Group: DynoMotion Message: 9519 From: TKSOFT Date: 5/22/2014
Subject: KMotion/KFlop Test Version 4.33a Available
Hardware/Software FRO Range Control – Instant Response / Optimal Acceleration!
http://dynomotion.com/Help/KMotionCNC/ToolSetupScreenTP.htm#Feed_Rate_Override
Forward/Reverse in Feed Hold!
http://dynomotion.com/Help/KMotionCNC/KMotionCNC.htm#Feed_Hold
See Video!
http://dynomotion.com/Videos/HWFRO.mp4
New Tool Table – 99 Tools Referenced by ID or Slot!  3D Images.
http://dynomotion.com/Help/KMotionCNC/KMotionCNC.htm#Tool
Data Starvation Protection!
Lathe Support – Threading - G32 – Radius/Diameter – X Front/Back!
https://www.youtube.com/watch?v=B-1TtrbAfwc
https://www.youtube.com/watch?v=oZPLGWmjgcI
Optimized GCode Viewer Graphics!
MDI Improvements!
Real Time Status!  Removes Interpreter Lookahead issues with Line number, Feed Rate, Fixture, etc.  Even in Reverse!
Bug Fixes and More!
More details:
http://dynomotion.com/Software/KMotion%20Released%20Version%204.33a%20Changes.pdf
Download Here:
http://dynomotion.com/Software/KMotion433a.exe
Please try and report any issues.
Group: DynoMotion Message: 9522 From: ericncn Date: 5/23/2014
Subject: Re: KMotion/KFlop Test Version 4.33a Available
Thank you Tom for giving a way for referencing the tools by ID.
However now when calling the ToolTableSet.c function it initially does nothing, and after insisting, it messes up the tool table completey.
This bug isn't new, I was using 4.31 earlier, and still ToolTableSet.c was messing the tool table, but in a different way...
EC
See Video!
MDI Improvements!
Bug Fixes and More!
More details:
Download Here:
Group: DynoMotion Message: 9528 From: Tom Kerekes Date: 5/24/2014
Hi EC,
Please try this new Test Version 4.33b
http://dynomotion.com/Software/KMotion433b.exe
There are some fixes for the new Tool table Format in these files:
ToolTableSet.c
KflopToKMotionCNCFunctions.c
Also some fixes in KMotionCNC.
Group: DynoMotion Message: 9529 From: Tom Kerekes Date: 5/24/2014
Hi EC,
ToolTableSet.c
Group: DynoMotion Message: 9535 From: ericncn Date: 5/25/2014
Thank you for the fix!
I've tested it shortly and it seems to work again!
I've a few comments about the way the tools IDs behave.. not really an issue, I'm happy with the way it works now and I need no more changes. Thank you.
Just wanted to share my observations:
- the release announcement says that 4 or more digits can be used; to be more precise the allowed range is 0001 ... 99999 as 00000 or 100000 (or more) will give error when invoked from the G-code
- actually the usable range is less than that as e.g. IDs like 0037 or 0005 will be translated like 37 or 5 and then confused as slots ID.
It looks me that the actual range for IDs is [1000 to  99999]
Again, this is not a complaint and I'm hapyy the way it works
Thank you again
EC
Hi EC,
ToolTableSet.c
Group: DynoMotion Message: 9538 From: Tom Kerekes Date: 5/26/2014
Hi EC,
Thanks for the feedback.  Yes we should have been more clear that IDs are numbers that require 4 or 5 digits.
